SPA2102 Line 1 "Not Registered"
Aug 10th, 2009
The SPA2102 is running firmware 5.2.5. Line 2 works fine. If I set up line 2 incorrectly, I get "failed" as expected. Line 1 is another story. No matter how I set up line 1, the status remains "Not Registered". It would seem that the line is not enabled even though the SPA acknowledges it as enabled in the GUI.
The syslogs show line 2 authenticating just fine. The only thing in the syslogs for line one is "sip skt[0]= INVALID".
I have tried resetting the SPA back to the factory defaults with no luck.
I also tried downgrading the firmware from 5.2.5 to 5.2.3 but the SPA does not take the downgrade. And yes, I have the firmware revision on the provisioning page set to 5.2.0.
Any thoughts would be greatly appreciated.
Patrick Born Mon, 08/10/2009 - 14:15
Hi kegagnon,
Could line 1 fail to register because it's trying to register when line 2 has already grabbed the registration?
Another thought, could the browser's cache be causing confusion?
Please share:
  1. the config from when line 2 is configured and registered
  2. the config from when line 1 is configured and not registered
Capturing config: https://www.myciscocommunity.com/docs/DOC-5101
Patrick
kegagnon Mon, 08/10/2009 - 16:10
Patrick,
Thank you for the prompt reply. Let me start by replying to your suppositions:
Query: Could line 1 fail to register because it's trying to register when line 2 has already grabbed the registration?
Response: I don't believe so but I have attached the configs so you can be the judge.
Query: Another thought, could the browser's cache be causing confusion?
Response: I don't think so. There are 4 LED's on the SPA. The second one from the right is off.
Thanks for the help.
Best Regards, Kevin
Patrick Born Thu, 08/13/2009 - 15:07
Kevin,
Looking at your config, I see that this is a customized SPA2102.
        Voice tab > Info tab > Product Information > Customization: Sunrocket
Line 1 is essentially hard-coded to work with Sunrocket, regardless of what changes you make on the Line 1 tab.
Now that Sunrocket is out of the picture, what you have is a SPA2102 with only Line 2 being configurable.
Patrick
kegagnon Sun, 08/16/2009 - 14:37
Patrick,
Yes, the Sunrocket customization is causing all the difficulty.
Deleting all entries from Voice >> System >> System Configuration >> Restricted Access Domains caused everything to start working. Line 1 registered and the firmware updated using tftp.
Thank you for your time and attention to this matter.
Best Regards, Kevin
