Rx Neighbors & Co-channel Infterference
Aug 10th, 2009
Hi all,
With an 802.11G WLAN if my AP's can see 1 or more AP's on the same channel as itself within Rx Neighbours could this be a indication of co-channel interference? - Or would this only be the case if the RSSI of the Rx Neighbor on the same channel was above a certain level?
Neil
aghaznavi Fri, 08/14/2009 - 07:21
  • Silver, 250 points or more
AP has a neighbor on same channel for 2.4 GHz radio, with power. These reports on possible co-channel interference. This may or may not be relevant depending on power and application used. AP has a neighbor on same channel for 5 GHz radio, with power. These reports on possible co-channel interference. This may or may not be relevant depending on power and application used. AP has a neighbor on an adjacent channel for X GHz radio, with power. This reports possible adjacent channel interference, which may be disruptive depending on how far is the AP on channel distance, and the power received
