08-10-2009 10:53 AM - edited 03-06-2019 07:10 AM
Somehow one of my co-workers configured a series of switches for a customer without an enable password so now when you attempt to connect to them via telnet you get the 'no enable password set' error. Is there anyway to fix this without having to individually touch each one and reconfiguring it?
Solved! Go to Solution.
08-10-2009 10:55 AM
You could try to set one via snmp if you have that enabled for write access, otherwise you'll need to reconfigure the switches.
HTH,
John
08-10-2009 11:16 AM
If you have console access to it, it will be pretty fast, you can set it over a console connection.
Else you can configure over snmp but only if you have an SNMP RW string. I can post details on how to achieve this via snmp, but make sure you have an RW community string
08-10-2009 10:55 AM
HTH,
John
08-10-2009 11:16 AM
08-10-2009 11:17 AM
One way to fix it remotely is to put the switches on a terminal server using their console port.
You should then telnet into the switches through the terminal server and configure them.
The drawback is that you need a terminal server on the site where the switches are located.
Cheers:
Istvan
