FXO call disconnect problem after 180s
Answered Question
I have a voice gateway with FXO ports and the calls are disconnecting after 180 seconds.
With "debug voice vtsp all" enable:
lpvgw01#
Aug 10 18:16:15.324: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_ring_noan_timer_start:
Timer Start Time=118723786, No Answer Timer Value=180000(ms)
Aug 10 18:16:15.324: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/act_setup_pend_alert:
Ringback Indication=FALSE, Ring Timeout=180(s)
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:[email protected]
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_status_cb:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_fax_config:
Fax Relay=DISABLED - 'fax rate disabled' set (dial-peer)
Primary Fax Protocol=IGNORE_FAX_RELAY, Fallback Fax Protocol=IGNORE_FAX_RELAY
Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
Fax Parameters Set By=Dialpeer, Peer=1
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_fax_feat_param:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_tty_config:
Save TTY configuration
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_tty_feat_param:
Set TTY feat parameters
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_DO_CAPS_IND]
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_peer_event_cb:
Event=E_DSM_CC_CAPS_ACK
Aug 10 18:16:15.368: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_CAPS_IND]
Aug 10 18:16:15.368: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_peer_event_cb:
Event=E_DSM_CC_CALL_MODIFY
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_feature_notify_cb:
Feature ID=0, Feature Status=1
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:[email protected]
Aug 10 18:16:23.956: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_media_event_cb:
Event=E_DSMP_DSP_ANS_SUP
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_RING_NOAN_TIMER]
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/act_ring_noan_timer:
No Answer Timer Expired
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_cc_call_disconnected:
Cause Value=19
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_set_release_source:
Release Direction=Internal, Release Source=Internal Release-PSTN
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_status_cb:
Aug 10 18:19:15.330: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_DISCONNECT]
lpvgw01#
Aug 10 18:16:15
Aug 10 18:19:15
This is the configuration of the FXO port:
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone
cptone BR
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
connection plar 10002
I already configured the "timeouts ringing infinity" but doesn't work.
Correct Answer by paolo bevilacqua about 7 years 9 months ago
It's telling you very cleary...
you need
no supervisory answer dualtone
The, supervisory disconnect likely won't work as that, but that's another issue.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Mon, 08/10/2009 - 13:54
  • Hall of Fame,
    Founding Member
you need
paolo bevilacqua Tue, 08/11/2009 - 01:51
  • Hall of Fame,
    Founding Member
Very good, thanks for the nice rating and good luck!
