Remove dial 9 for one analog extension
Answered Question
Aug 10th, 2009
Hi, I have a fax modem that gets it's outbound numbers from a proprietary application (not mine). The fax modem is set for "dial as entered", I would like to use it on the outbound sip trunk, but need to disable dialing the 9 to access an outside line..
Correct Answer by Steven Smith about 7 years 9 months ago
You could put a translation profile on the ephone-dn that adds a 9.  This wouldn't be CCA supported, but it would mean not having to change the rest of your dial plan.
config t
ephone-dn 4
voice translation-profile outgoing faxadd9
voice translation-profile faxadd9
translate calling 4
voice translation-rule 4
rule 1 /\(^.*\)/ /9\1/
Something like that should work.  Use this page for a reference.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Smith Mon, 08/10/2009 - 12:49
  • Gold, 750 points or more
config t
ephone-dn 4
translate calling 4
David Harper Mon, 08/10/2009 - 16:41
  • Cisco Employee,
If I understand you correctly, the number is being provided from the application to the modem without a 9, the modem then dials that number without the 9 to the UC500 FXS port, and then the call needs to be routed out the SIP trunk.
Assuming I am correct, there are a couple of small errors in the above config (It must have been late when Steven typed his reply ;) ).  First, since from the perspective of the UC500, the call is coming in the FXS port, the translation-profile under the ephone-dn needs to be incoming, not outgoing.  ie:
ephone-dn 4
voice translation-profile incoming faxadd9
And second, the number that needs to be modified is the called number, not the calling number.  ie:
translate called 4
Also, this will only work if the FXS port is set up as a User Phone under Analog Port Settings in CCA.  If it is set up as a Common  Area Phone or as a Fax, then the config is slightly different.
Cheers,
Dave.
