Load balancing help
Aug 10th, 2009
Greetings,
Please refer to the attached diagram. Basically i have a remote site with dual connections and i want to be able to load balance outgoing remote site traffic going to serverA. The problem here is that i cant run a routing protocol from the PIX to the WAN routers which makes it difficult to split the load.
Thanks in advance for the input.
