Collin Clark Tue, 08/11/2009 - 07:15
  • Purple, 4500 points or more
Do you mean the router will provide the two gateways? Use a secondary IP or trunk and use sub-interfaces for each subnet.
Do you mean you have two destination gateways?
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 2.2.2.2
smitesh kharecha Fri, 04/30/2010 - 06:33
  • Silver, 250 points or more
collin,
having 2 deafult routes will probably solve the problem, but it will use only one gateway to forward the traffic.
Router will use CEF and pass traffic to one gateway and if that gateway goes down, it will switch over to another one.
Smitesh Kharecha
shailesh.h Fri, 05/07/2010 - 08:31
  • Bronze, 100 points or more
Kindly elaborate more on the scenario
Shailesh
