Change IOS on 1131AG AP from Lightweight to Autonomous
Answered Question
Aug 10th, 2009
hi experts,
can someone advice if the 1131ag ap's IOS can be changed to autonomous? can you give me a link where i could get an autonomous IOS and how to do it? thanks!
Correct Answer by Lucien Avramov about 7 years 6 months ago
Correct
Correct Answer by Leo Laohoo about 7 years 6 months ago
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Set the timeout value on the TFTP server to 30 seconds.
Step 4 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 5 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 6 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 7 Disconnect power from the access point.
Step 8 Press and hold MODE while you reconnect power to the access point.
Step 9 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 10 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 11 After the access point reboots, reconfigure it using the GUI or the CLI.
Overall Rating: 5 (2 ratings)
Correct Answer
Leo Laohoo Mon, 08/10/2009 - 19:37
johnlloyd_13 Mon, 08/10/2009 - 22:01
thanks! i've downloaded these at cisco.com website. just want to verify if these IOS image are autonomous:
c1130-k9w7-tar.124-10b.JDA.tar
c1130-k9w7-tar.124-3g.JA1.tar
