CTI port issue
Aug 10th, 2009
I have configured the CUE with the CTI ports and all are registered on the Call Manager but when I tried to call the voice mail from the IP phones it sounds engage tone; if I call the direct DID number I can hear the greeting so I guess there is something wrong with the CTI because I can see the voicemail number re-direct to CTI number. Anyone have this kinda experience? Don't mind to share with me your solutions. Thanks.
Rob Huffman Tue, 08/11/2009 - 05:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Wooi,
I don't think the problem lies with the CTI portion of the config :) If you are trying to call using the Message button on the IP Phones, I think this is missing;
Configure Voice Mail Profiles
Voice mail profiles provide an easy way to manage multiple voice mail systems. A voice mail profile is used when you press the Messages button on a phone. Also, you can avoid the need to manually configure the CFB and CFNA numbers when you forward calls to voice mail.
The voice mail pilot number is configured with the DN on the CTI route point that is configured for voice mail.
The Cisco CallManager Administration Guide explains in detail how to configure a voice mail profile. But, you generally only need to add a pilot number and then a voice mail profile, usually a name is selected that identifies the remote site, with the pilot number selected. The profile is then applied to individual phone DNs. This enables you to check the Voicemail selection for CFB, CFNA, or even Call Forward All (CFwdAll).
CallManager for Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Hope this helps!
Rob
