Activating NAM HTTPS server
Answered Question
Aug 11th, 2009
Hi, I have activated https server in a NAM following the procedure in After I have loaded successfully the patch, I try to activate the server, but the following error occurs:
[email protected]# ip http secure server enable
Enabling HTTP secure server...
ERROR: Failed to enable HTTP secure server.
I have this NAM configuration:
Fri Aug 7 23:53:19 2009 Patch: nam-app.3-6.strong-crypto-patchK9-1-0 Description: Strong Crypto Patch for NAM.
IP address: x.x.x.x
Subnet mask: x.x.x.x
IP Broadcast: x.x.x.x
DNS Name: localhost.i-csnam-simb-c03.tsm.inet
Default Gateway: x.x.x.x
HTTP server: Disabled
HTTP secure server: Disabled
HTTP port: 80
HTTP secure port: 443
TACACS+ configured: No
Telnet: Disabled
SSH: Disabled
I have seen also the following error:
[Sat Aug 08 00:02:59 2009] [warn] RSA server certificate CommonName (CN) `localhost.i-csnam-simb-c03.tsm.inet' does NOT match server name!?
[Sat Aug 08 00:02:59 2009] [error] Unable to configure RSA server private key
[Sat Aug 08 00:02:59 2009] [error] SSL Library Error: 185073780 error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch
Does anyone know what is going wrong?
Thanks in advanced.
Correct Answer by Lucien Avramov about 7 years 2 months ago
CN=hostname.domain so that is fine.
Try the other steps i mentioned earlier and revert your results.
Overall Rating: 5 (1 ratings)
Lucien Avramov Tue, 08/11/2009 - 00:27
Make sure you configure correctly the hostname of the nam
Try a config clear from the NAM CLI and try again.
If that doesnt help, try to reimage the nam with the --install option.
If it still the same issue, please post the show-tech from the NAM so I can have a look
luis.elvira Tue, 08/11/2009 - 01:41
Hi lavramov,
I have checked the configuration and really the hostname is not the same that th CN in the certificate:
ip host "localhost"
ip domain "i-csnam-simb-c03.tsm.inet"
So, have we to change the certificate CN to localhost??
Thank you very much,
Correct Answer
Lucien Avramov Tue, 08/11/2009 - 15:46
luis.elvira Wed, 08/12/2009 - 22:59
Thank you very much, I made clear config and confire again and now it works :)
