LMS 2.6 remote configuration
Joe Clarke Tue, 08/11/2009 - 06:46
Assuming you want to push a small configuration change to a large number of devices, you use the RME Netconfig tool for that. Go to RME > Config Mgmt > Netconfig > Netconfig Jobs, and create a new job. Select the devices to which you want to deploy the changes, then select the configuration templates. See the context-sensitive online help for more details about what each template provides.
