Dual ACS solution (4.2) with one ACS doing the authenticating, the other acting as a standby.
Recently when accessing nortel switches, they authenticate to both ACS, as some are going to ACS2 despite their primary RADIUS server being ACS1.
The ACS solution has other network devices, using TACACS+ and they seem fine. DB replication is fine between the ACS and nothing I believe has changed in the configuration between the two.
Any ideas? (all I can think is the response from ACS1 is exceeding the timeout and the switches then select ACS2, but there's no evidence to suggest a problem in network delay).
