Network Design (BGP)
Aug 11th, 2009
Looking for a routing solution so traffic will pass over the primary MPLS circuit (ISP A) on Site A, and use the secondary MPLs circuit (ISP B) as a backup solution only)
Site A
EIGRP routing running between all switches and routers (SW1_A, SW2_A, R1_A & R2_A).
HSRP running between switches (SW1_A & SW2_A).
Should I change the metric for the BGP routes for the backup circuit on site A & B.
Jon Marshall Tue, 08/11/2009 - 05:18
Colm
1) Are you redistributing BGP into EIGRP
2) Are you redistributing EIGRP into BGP
3) Are you running IBGP between R1_A & R2_A
4) Are you running IGBP between R1_B and R2_B
If you are redistributing BGP into EIGRP then at first glance the easiest solution would be to have R2_A generate a default route into EIGRP in site A and stop R2_A redistributing BGP into EIGRP.
On R1_A continue to redistribute BGP into EIGRP.
Then under normal circumstances the more specific routes from BGP that are redistributed into EIGRP will be used and only if that link fails will the default route via R2_A be utilised.
Jon
colmgrier Tue, 08/11/2009 - 05:47
Jon,
Yes, all BGP routes from remote sites are being redistributed into EIGRP (Site A)
No, I'm using the network command under BGP, to advertise selected networks from the routing table over BGP (Site A)
No. I cant run IBGP between R1_A & R2_A because the MPLS circuits are provided by different ISPs and therefore use different BGP AS numbers
Same as 3.
Colm
colmgrier Tue, 08/11/2009 - 06:13
Jon,
Could you explan the below with an example config. See below for current configuration for Site A.
Site A
### R1_A ###
interface GigabitEthernet0/0
description "LAN"
ip address 10.1.20.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description "MPLS (Primary)"
ip address 89.124.200.6 255.255.255.252
router eigrp 90
redistribute bgp 70000 metric 128 50 255 100 1500
network 10.1.20.0 0.0.0.255
no auto-summary
router bgp 70000
no synchronization
bgp log-neighbor-changes
network 10.1.20.0 mask 255.255.255.0
network 10.1.21.0 mask 255.255.255.0
neighbor 89.124.200.5 remote-as 3000
no auto-summary
### R2_A ###
description "LAN"
ip address 10.1.20.6 255.255.255.0
duplex auto
speed auto
description "MPLS (Backup)"
ip address 89.124.100.6 255.255.255.252
router eigrp 90
redistribute bgp 65000 metric 128 50 255 100 1500
no auto-summary
router bgp 65000
no synchronization
neighbor 89.124.100.5 remote-as 2500
no auto-summary
### SW1_A ###
interface Vlan20
description "LAN_1"
ip address 10.1.20.2 255.255.255.0
standby 20 ip 10.1.20.1
standby 20 priority 105
standby 20 preempt
standby 20 authentication C1sc0
standby 20 track GigabitEthernet1/1
interface Vlan21
description "LAN_2"
ip address 10.1.21.2 255.255.255.0
standby 21 ip 10.1.21.1
standby 21 priority 105
standby 21 preempt
standby 21 authentication C1sc0
standby 21 track GigabitEthernet1/1
router eigrp 90
netork 10.1.20.0 0.0.0.255
netork 10.1.21.0 0.0.0.255
no auto-summary
### SW2_A ###
interface Vlan20
description "LAN_1"
ip address 10.1.20.3 255.255.255.0
standby 20 preempt
interface Vlan21
description "LAN_2"
ip address 10.1.21.3 255.255.255.0
standby 21 preempt
router eigrp 90
no auto-summary
Colm
Jon Marshall Tue, 08/11/2009 - 06:51
Colm
R2_A
ip route 0.0.0.0 0.0.0.0 89.124.100.5 (this is the ISP next-hop interface)
router eigrp 90
redistribute static
no auto-summary
the above config would advertise a default-route back into Site A.
There are other ways this could be done by using an EIGRP summary address but the above should work fine.
Jon
colmgrier Tue, 08/11/2009 - 07:19
Jon,
Let me get this straight, just a bit confused. On R2_A I only need the addition config for the static route.
Therefore: If R1_A failes all traffic will use the backup circuit (ingress/egress)
router eigrp 90
redistribute static
no auto-summary
router bgp 65000
no synchronization
no auto-summary
Jon Marshall Tue, 08/11/2009 - 08:12
Colm
You will need to do the same on R2_B so that traffic coming back to site A will use the primary link under normal conditions and only use the backup link if the primary link fails.
Apart from that your config above is fine.
Jon
