Is it Possible to enable or have more than one RAP in a Mesh Network?
Aug 11th, 2009
Hi all,
My WLAN has a 4404 WCS and is running in mesh mode. The area of coverage is wide and i need to have extra RAPs in strategic locations to minimize the hop count of some outdoor APs. The extra RAPs are wired back to the switch via fibre. How can i enable more than one RAP in this case? Please help!!!
Overall Rating: 5 (1 ratings)
dancampb Tue, 08/11/2009 - 05:35
Sure, you can have multiple RAPs. Just set the role of any AP that can hit the controller via the wire as a RAP. The MAPs will then use the best route to the controller. If you want to specify which MAPs go to a particular RAP just set different BGN's. Also I would suggest setting different channels for each RAP.
richnam Tue, 08/11/2009 - 05:42
Thank you dancampb.
I have set the role of another AP to root. but however, i noticed all the other MAPs leave the previous RAP and associates only to the new one. How do i set different BGNs? what is a BGN? my WCS runs a mesh network but i don't see any bridging enabled. please i need your help.
richnam Wed, 08/12/2009 - 08:36
Thank you dancampb.
I was able to set up a second RAP. However, that means if the RAP goes down, all the MAP connected to that BGN will be down. Is there a way i can make the group fallback to another group incase the groups RAP goes down?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
