ATA186 Speeddial
Aug 11th, 2009
Hi there !
Is there any chance of disable the speed dial feature in ATA186 ?
In my dial-plan I'm using * as a special code for international call (*5 + 1000... *4 + 1000... etc) and this * is used by ATA speed dial.
Thanks.
Andrei.
ivillegas Mon, 08/17/2009 - 10:05
You cannot remove the speed dials from the ATA button template. Use a translation pattern instead that would append a * when trying to CMC codes for ATA.
