Port Utilization reports on LMS3.1
Aug 11th, 2009
I am looking for a way to pull a report that will give me the port utilization % for each device. I have scrubed this application and to no avail. I am running LMS 3.1 on Windows. I have RME, DFM, IPM, Campus Manager all installed.
Can someone point me in the right direction?
Thank you
Joe Clarke Tue, 08/11/2009 - 07:40
You will need to install the Health and Utilization Monitor add-on. By default, you will get a 90-day of HUM. You can then configure an Interface Utilization poller for your devices which will provide you what you want.
DHARSH_01 Wed, 08/12/2009 - 04:38
Thank you jclark
I have Unified Operations Manager as well. I found a report that says VG utilization. But when I run the report, it only tells me the status of the VG's, not the utilization. Is there a way to get report port utilization from the OM on the Voice Gateways?
Joe Clarke Wed, 08/12/2009 - 07:55
You should start a new thread for the OM question. I know OM tracks utilization, but it will not maintain a history as HUM will do.
