Default for CEF on Switches
Aug 11th, 2009
I have been reading and reading and trying to figure out the defaults for 'ip cef' and 'ip cef distributed' on Catalyst Switches.
i.e. 3750, 3560s, 2950s, 2940s, 4500s and 6500s.
Wouldn't/Isn't the default that Cisco Expressing Forwarding is enabled.
The command references as well as the command lookup tool are very elusive/cryptic regarding this IMHO.
It should just be stated clearly.
Can someone tell me and assure what the story is and
what the defaults are for 'ip cef'?
Jim Abercromby
Reza Sharifi Tue, 08/11/2009 - 08:06
Jim,
This is from Cisco IOS command reference:
Command Default
Cisco Express Forwarding is enabled by default on most platforms. To find out if Cisco Express Forwarding is enabled by default on your platform, enter the show ip cef command.
Reza
