C4K_SWITCHINGENGINEMAN-3-PPECELLDUPDETECTED: Free cell duplicate(s)
Answered Question
Aug 11th, 2009
Anybody knows why this message C4K_SWITCHINGENGINEMAN-3-PPECELLDUPDETECTED: Free cell duplicate(s)
detected [hex]. System will be reset!
ocurrs?
I only found this on Cisco
Error Message C4K_SWITCHINGENGINEMAN-3-PPECELLDUPDETECTED: Free cell duplicate(s)
Explanation The system detected free cell duplication, and will be reset. This message may also erroneously appear when using jumbo packets or if sharing is configured and transmit queues have backed up.
Recommended Action This is an informational message only. No action is required.
But there is not solution or what can i do.
Is hardware issue?
Best Regards.
Correct Answer by jbrenesj about 7 years 9 months ago
Yes, the first one is just about increasing the severity of the message to critical. The second one is the one you need to keep an aye on so you can see when a fix is released.
Overall Rating: 5 (2 ratings)
jbrenesj Tue, 08/11/2009 - 09:25
  • Silver, 250 points or more
Are you running 12.2(31)SGA?
If so this is a software bug. Two I can recall:
CSCsq34620
PPECELLDUPDETECTED message level should be "critical"
Fixed in 12.2(31)SGA8
CSCsg28982
Crash due to C4K_SWITCHINGENGINEMAN-3-PPECELLDUPDETECTED
rgonzalch Tue, 08/11/2009 - 09:58
Hi jbrenesj,
Thanks for you answer but i am running 12.2(31)SGA8.
Best Regards.
rgonzalch Tue, 08/11/2009 - 10:02
Hi jbrenesj,
I saw the second bug CSCsg28982 on bugtoolkit and seem it is the problem
and does not have solution yet :s.
Best Regards.
Correct Answer
jbrenesj Tue, 08/11/2009 - 11:01
rgonzalch Thu, 08/13/2009 - 11:03
Hi jbrenesj,
I opened a case with TAC and they say that it is hardware problem with the processor of the sw.
Another thing the bug is on status closed. That`s means never will be fixed! jaja
Best Regards.
