Quick Question - Trunking
Aug 11th, 2009
How can you view which port(s) are designated trunk ports? On a 3524 xl, I set a port to trunk mode and doing sh int or sh run or sh vlan does not indicate anywhere that this port is in trunk mode.
thanks
Overall Rating: 5 (1 ratings)
Istvan_Rabai Tue, 08/11/2009 - 09:57
  • Gold, 750 points or more
Try "show interface trunk" or "show interface status"
Though it may happen that in these old switches these commands did not exist.
Cheers:
Istvan
dj214 Tue, 08/11/2009 - 10:01
neither worked. that seems crazy not to be able to determine which port is trunked.
Edison Ortiz Tue, 08/11/2009 - 10:00
  • Hall of Fame,
    Founding Member
'show interface fx/x switchport'
HTH,
__
Edison
