Cisco 6509 High Cpu
Aug 11th, 2009
Hi;
When we check the cpu usage of the switch ,we take this output.
Isn't it high ? What could we do to reduce ?
We have about seventy vlan with HSRP, eighty edge switches with fiber. We dont use BGP protocol, only a few static routes.
Thanks.
Ios ver : Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
Overall Rating: 5 (1 ratings)
Lucien Avramov Tue, 08/11/2009 - 10:33
  • Red, 2250 points or more
Your CPU output seems completely fine.
I suggest the use of the command show proc cpu history, that will show you when spikes happen.
It's OK to have high CPU on a a router, it depends what it's doing.
20% of CPU is completely fine, you should not worry about it.
