Dot11Radio 0 Reset Status
Aug 11th, 2009
Hi all,
I'm troublehooting a Reset Radio Interface, wich is stucked in Reset Status.
I think its all configured, but the Radio dont comes up.
I've not GUI access, so im configuring all by CLI (telnet).
In attach i post the configurationof the AP, as weel as other output that i think u might be interested.
In WLSE, when i see Fault Reports, it appears the following messages:
Inconsistent device state found: Device "AP-36.luvzone.ulusofona.pt": ifIndex=1, MAC=00-24-14-8c-f9-80: "CISCO-DOT11-IF-MIB cd11IfStationConfigTable.cd11IfStationRole must be in the range [1..11] (was 0)"
Anyone knows what is the problem ?
Best Regards,
Bruno Petrónio
dancampb Tue, 08/11/2009 - 11:23
The subinterfaces are off with this configuration. The AP only shows having a b/g radio (dot11Radio0) but all of the subinterfaces are assigned to dot11Radio1. Because of this the VLANs aren't created on the radio interface and it won't come up. Try deleting the current subinterfaces and recreating them under the dot11Radio0 interface.
