erspan session keeps shutdown
alfonso.cornejo
Level 3
Level 3
Hi to all,
I've configured an erspan session between two Cat6509 but in the source, the monitor session is always "shutdown" and it doesn't change when i put the no shutdown command.
Here is the configuration:
SOURCE
monitor session 12 type erspan-source
shutdown ->***THIS IS THE ONE THAT NEVER GOES OUT***
source vlan 121
destination
erspan-id 112
ip address 10.233.48.228
origin ip address 10.233.48.248
DESTINATION
monitor session 12 type erspan-destination
destination interface Fa4/3
source
erspan-id 112
When i do a sh monitor session 12 detail it says in the status field Admin Disabled
Do you know what can be causing this?
Thanks in advance for your help.
alfonso.cornejo
Level 3
Level 3
*SOLVED*
The problem was that the next hop address of the source (10.233.48.228) was known by a tunnel and that is not supported by erspan, just have to take the destination address out of the tunnel.
Here is the cisco information:
%SPAN-5-ERSPAN_ADJ_TUNNEL: ERSPAN Destination behind a tunnel. Shutting down session [dec]
The next hop to the IP address specified as the ERSPAN destination lies behind a tunnel. This configuration is not supported. The ERSPAN session is shut down when such a configuration is detected.
Recommended Action: Specify another ERSPAN destination IP address that does not have a tunnel as the next-hop adjacency.
Related documents- No specific documents apply to this error message.
Hope this help someone in the future...
