ADSchemaSetup for Unity 7.x
Aug 11th, 2009
When I run the ADSchemaSetup for Unity 7.0(2) everything is fine except the following:
2009-08-11 21:46:46 Error ADsGetObject(cisco-Ecsbu-UM-Schema-Version) failed E:\views\CU7.0.1.28\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 1319
2009-08-11 21:47:06 Error spSchemaContainer->Get failed with error 0x8000500D. E:\views\CU7.0.1.28\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 723
2009-08-11 21:47:06 Error IsValueInAllowedChildClassesEffective failed with error 0x8000500D. E:\views\CU7.0.1.28\un_Setup\ADSchemaSetup\ADSchemaSetup\ADSchemaSetupDialog.cpp 219
This config is an on-box mail store using off-box Domain Controller.
I am running the wizard from a shared DVD drive on the Unity box because the DC only has a CD.
Thank you in advance for your help.
Hoan Mai Tue, 08/11/2009 - 14:11
1. Make sure that you are logged on to the Schema Master.
2. Make sure you are a member of the Schema Admins security group.
voipis4me Tue, 08/11/2009 - 14:16
The Wizard completed successfully after I added the account to the Enterprise Admins Group.
Thanks.
