Text Resource
Aug 11th, 2009
I have a quick question concerning Text Resource.
For example, after creating a notification we can edit and modify its content. However is there a way to modify the name of the notification ?
Or only solution is to copy and create a new notification ?
Raph
Andrew Wurster Wed, 08/12/2009 - 18:05
i don't think so... however you MAY be able to pull off your config XML file and find the appropriate tags in there, alter their values, and reload the file.
i vote for copying the stuff to a new resource, however. having staging profiles and policies and such that you can test with is.a.good.habit!
andrew
