sup-bootdisk: (no such device)
Aug 11th, 2009
Hello all
I have been trying to upgrade is the IOS on my 6509 router. I tried to backup the older IOS onto the TFTP server but it failed half way and now the file is gone from sup-bootdisk: It also shows the error message sup-bootdisk: (no such device) when I try to do show sup-bootdisk:
Any suggestions on get the sup-bootdisk back?
thanks
rhnpdss123 Tue, 08/11/2009 - 18:57
I believe it didnt show the sup-bootdisk: it - on space usuage and - on space remaining.
I will verify it again
chinkevi_2 Tue, 08/11/2009 - 23:06
it depends on your supervisor type, and if currently running catos or ios. If the suggestion that dir /all doesn't show you anything, best to check the documentation on your supervisor type.
if you have removable flash or disk, you can try disk0: or slot0:.
