Problem with SSHv2 from Cisco 6500 to Nortel 8600
Aug 11th, 2009
I have a situation where a client has a mixed vendor network. The client needs to be able to open SSH v2 sessions from one device to another in a "hop-to-hop" situation in case of faults.
The issue arises when trying to SSH from a cat6500 to a Nortel 8600 where basically the SSH connection fails. If using SSH v1, the connection works, if using another SSH client to connect SSH v2 to the Nortel the connection succeeds. However, using the inbuilt SSH client on the cat 6500 fails with a "SSH CLIENTTO: key exchenge failure (code = 0)" in the Cisco debug and a "SSH ERROR no hostkey alg" in the Nortel Log.
Attached is a text file showing some of the debug output and log output from both devices.
The 6500 is running s222-ipservicesk9_wan-mz.122-18.SXF8.bin.
Any help would be appreciated. Including the fact I may have missed something obvious.
Note: I have a Nortel colleague also looking into this.
Cheers
Rob
obrien-r Wed, 08/12/2009 - 14:44
As provided by Iavramov in the LAN/Switching discussion I opened, it would appear I have stumbled on the is a bug for this:
CSCsm76370 Unable to SSHv2 to Nortel switch (from cisco device)
Apparently as the Cisco ssh is working fine with all the other clients like putty,open ssh and others, the problem is with the Nortel. However, these other clients also all work with the Nortel, so it would appear there is an incompatibility between the two vendor implementations.
So it looks as if this just will not work.
