Hardware compatibility for existing production servers
Dear all,
My customer currently has existing servers running CUCM 5.0 & Unity Connection 1.x and would like to get upgraded to CUCM 7.1 & Unity Connection 7.0. Just wondering whether their existing hardware supports the upgrade.
MCS-7835I-K9-CM50 (Now: CUCM 5.0, wants upgrade to CUCM 7.1)
MCS-7835I-I1-UC1 (Now: Unity Conn 1.x, wants upgrade to Unity Conn 7.0)
IBM X346 8840-21A (Brand new install for MeetingPlace Express 2.0)
Is this possible??
As an alternative, my client have many spare IBM X346 8840-21A servers and would like to know whether they would support for installation for:
1. CUCM 7.1
2. Unity Connection 7.0
3. MeetingPlace Express 2.0
Would greatly appreciated your help.
Cheers,
Hunt
Jaime Valencia Tue, 08/11/2009 - 18:56
  • Cisco Employee,
  • Hall of Fame,
    2011
That info is already available on CCO and there are plenty of other posts asking server compatibility, refer to the tables
Cisco Unity Connection 7.0 Supported Platforms List
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps6509/data_sheet_c78-491743.html
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
As per NON-MCS refer to this links to see if they meet the requirements and if the equivalent supports the product you want to install on it
Cisco 7800 Series Media Convergence Servers
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/product_solution_overview_list.html
java
if this helps, please rate
