Cisco LMS
Answered Question
Aug 11th, 2009
Does Cisco LMS has a built-in Syslog capability? Standard or Extended.
Correct Answer by Joe Clarke about 7 years 7 months ago
The Windows version of LMS includes a built-in syslog server which only supports udp/514 syslog messages (syslog over TCP or BEEP is not supported). The Solaris version of LMS does not include its own syslog daemon. We rely on the OS syslogd.
However, we have recently started to support syslog-ng in LMS. The attached whitepaper should help if you want to set that up.
Overall Rating: 5 (1 ratings)
Lucien Avramov Tue, 08/11/2009 - 21:06
  • Red, 2250 points or more
Yes there is a syslog server with ciscoworks.
Not sure what you mean by standard or extended.
Correct Answer
Joe Clarke Tue, 08/11/2009 - 21:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
