BGP dmzlink command
Aug 11th, 2009
Hi experts,
I am analysing the command "bgp dmzlink-bw" command. In all the sites and
CISCO documents says that this command has to be used under "address-family
ip4".
But I am seeing this command appears even without getting into
"address-family ip4". What is the difference of using with or without using
"address-family ipv4"
NOTE: I am aware the purpose of "bgp dmzlink-bw" command
Can you please help me to understand this
regards,
sairam
Overall Rating: 5 (1 ratings)
huangedmc Tue, 08/11/2009 - 21:37
the address-family command is used when you implement multi-protocol BGP.
It's a way to distinguish between ipv4 & vpnv4 configs.
If you don't specify ipv4, everything falls under ipv4 global by default, which is just the plain old BGP.
