BGP path selection with 3 & 5th step
snarayanaraju
Level 4
Level 4
Dear Experts,
I am trying to understand BGP BEST PATH SELECTION criteria 3 & 5
Selection 3: Prefer the path that was locally generated using Network / redistribute / aggregate command
Selection 5: Prefer the path with Lowest origin type IGP < EGP < INCOMPLETE
In selection 3 REDISTRIBUTE also make the route with SYMBOL (?), selection 5 also states INCOMPLETE (?)
I find difficult to understand the concept. can you please explain with example so that i can understand this better
Thanks in advance
Sairam
Hi Sairam,
You should understand this the following way:
Step 3 in the BGP path selection process is executed if there are multiple paths with the same weight and local preference attributes (step 1 and step 2)
Step 5 in the BGP path selection process is executed if there are multiple paths with the same weight, local preference and AS_Path attributes and the paths are not originated by the local router (step 1 through step 4).
So the point is to go over the path selection process step by step until a tie breaker can be found.
Cheers:
Istvan
7 Replies 7
Istvan_Rabai
Level 7
Level 7
Hi Sathya,
In step 3:
The router will prefer the paths originated by the local router in the following order of preference:
The path was generated by:
1. default-information originate command
2. network command
3. aggregate-address command
4. redistribute command
This means for example that the path generated by the local router using the network command will be preferred over a similar path but generated by the redistribute command.
For example if you have a loopback0 interface 10.1.1.1/32 within the router and you want to advertise it.
Advertising it with the network command:
router bgp 65000
network 10.1.1.1 mask 255.255.255.255
Advertising it with the redistribute command:
route-map CONN
match interface loopback0
router bgp 65000
redistribute connected route-map CONN
The router will prefer the path originated by the network command and will advertise it to its neighbors.
In step 5:
The following origin codes exist:
1. IGP (i), its value in the updates = 0
2. EGP, its value in the updates = 1
3. Incomplete (?), its value in the updates = 2
1. When a path is originated using the default-information originate command, the network command or the aggregate-address command on some router, the path receives an origin code of 0 (presented as ' i ')
2. EGP is not used
3. When routes are originated with the redistribute command (routes are redistributed from another routing protocol e.g. from OSPF, EIGRP, RIP, or the static or connected routes are redistributed), the path receives an origin code of 2 (presented as '?')
Step 5 says:
Prefer the path with the lowest origin code.
This means that paths with origin code 0 (IGP) will be preferred to paths with origin code of 2 (incomplete).
Cheers:
Istvan
Hi Istvan,
A nice explanation with good efforts. Thanks.
I will summarize my understanding.
STEP 3: More relevant to the Routes originated in the Local router.
STEP 5: More relevant to the Routes that is received from peer neighbor.
Hope I understood it in right way. If it is wrong, sorry I will look into your explanation again
sairam
Hi Sairam,
Cheers:
Istvan
Hi Istvan,
Can you please explain the criteria that was used in selection of the best route in the output below?
sho ip bgp  10.0.0.0/8
BGP routing table entry for 10.0.0.0/8, version 5602427
Paths: (2 available, best #1, table Default-IP-Routing-Table)
  Advertised to update-groups:
  Local
    172.27.128.4 from 0.0.0.0 (172.21.255.206)
      Origin incomplete, metric 264960, localpref 100, weight 32768, valid, sourced, best
  Local, (aggregated by 65100 172.21.255.206)
    0.0.0.0 from 0.0.0.0 (172.21.255.206)
      Origin IGP, localpref 100, weight 32768, valid, aggregated, local, atomic-aggregate
Both routes are originated locally one by redistribution and the other by aggregation. Based on the order of preference you indicated above, the aggregate routes are prefered over the redistributed routes so I would have expected the second route to be the best.
Weight and local-pref are equal so I'm thinking the tie breaker was Step 3 ?
Even if it went down to Step 5, origin code for IGP should be prefered over  incomplete hence i would still expect the second route to be selected.
Would appreciate your insight.
Gb,
read step 3 here:
http://www.cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a0080094431.shtml
It says:
"Prefer the path that was locally originated via a network or aggregate BGP subcommand or through redistribution from an IGP.
Local paths that are sourced by the network  or redistribute commands are preferred over local aggregates that are sourced by the aggregate-address  command."
Best regards,
Milan
Got it thanks!
I guess Istvan should edit his first post and rearrange the order of preference for locally generated routes. He had put aggregate before redistributed which was misleading
My mistake, sorry.
Thank you for the correction.
The corrected post:
In step 3:
2. network command
3. redistribute command
4. aggregate-address command
Regards:
Istvan
