Replacing standalone bank of modems
I am looking to replace a bank of standalone dial in/out modems with a router and Digital modem configuration, Where i need assistance is how i might configure the Cisco router to communicate with a multiport serial adapter in a server. The Current modems are connected to the server via a multiport interface. I think a 16 port asyncronous card is the answer but how do i map the call info from the DM to the router serial interface.
Any Assistance would be great.
Many Thanks
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 08/12/2009 - 04:21
Check if the server/application can support connections over IP, that would be the easier solution. Alternatively, there are "virtual COM" device driver that can do this job.
The alternative would be placing an high density async card on the router, but better try to avoid if possble at all.
Paolo Bevilacqua Wed, 08/12/2009 - 07:01
Yes, you would use autocommand.
Yo do not necessarily need to map anything. If using the async card, put just put these vty lines in a rotary group and reference it for reverse telnet.
Please remember to rate useful posts with the scrollbox below.
