IP Access List Question
Aug 12th, 2009
Not an access list guy. Never had to do much of it...until today.
I hae a 3750 switch. Ports 1-4 are VLAN100 the rest are VLAN 1. I have a host 10.10.10.10 that needs to talk to the NTP server plugged into port 4 at 10.100.100.100. I don't want that host to talk to anyone else on that network.
I was just going to go to config mode and do an ip access-list 101 10.10.10.10 0.0.0.0 10.100.100.100 0.0.0.0 and thats it.
Anything better than that?
James
Overall Rating: 5 (2 ratings)
jfraasch Wed, 08/12/2009 - 05:33
One other quick question. On the 3750s, are the ports switchports by default? Or do I need to enter the command "switchport" on all interfaces to make them switchports?
Thanks again.
Collin Clark Wed, 08/12/2009 - 05:45
That would block everyone else too! Try something like-
ip access-list extended Allow_NTP
permit udp host 10.10.10.10 host 10.100.100.100 eq 123
deny ip host 10.10.10.10 any
permit ip any any
Hope that helps.
jfraasch Wed, 08/12/2009 - 06:52
I do want to block everyone else. Sorry I wasn't clear about that.
No other host on the 10.10.10 network should be able to go to VLAN 100.
James
Collin Clark Wed, 08/12/2009 - 06:55
Your more permissive statements should be at the top and then restrict down.
deny ip 10.10.10.0 0.0.0.255 any
Jon Marshall Wed, 08/12/2009 - 05:46
James
access-list 101 permit udp host 10.10.10.10 host 10.100.100.100 eq 123
access-list 101 deny ip host 10.10.10.10 10.100.100.0 0.0.0.255
access-list 101 permit ip any any
int vlan 1
ip access-group 101 in
the above will acl will -
1) allow 10.10.10.10 to use NTP with 10.100.100.100
2) stop all other traffic from 10.10.10.10 to any device on 10.100.100.0/24 network
3) allow all other traffic from either 10.10.10.10 to any other device ie. not a device on vlan 100
4) allow all traffic from every other device on 10.10.10.x network to any other device including all devices on vlan 100
Yes, by default ports are switchports.
Jon
jfraasch Wed, 08/12/2009 - 06:50
If I wanted all other hosts to be blocked from the 10.100.100.x network I would just not add the permit ip any any command, correct?
Also, you are simply locking the host access to the server down to the NTP protocol port. The way I had it would have allowed any type of connection between the devices.
Cool. That makes sense. Thanks.
Oh, I then have to apply the access list to VLAN 1. Forgot about that.
James
