QoS for video
Aug 12th, 2009
I am looking at implementing qos on our network for some ip surveilence cameras and also for streaming video from a quicktime server on mostly 2960 and 3560 switches. Can I use autoqos for this or am I better off creating MQC policies? If I use autoqos what would be the best configuration.
Thanks for your help.
andrew.prince@m... Wed, 08/12/2009 - 07:56
Firstly AutoQoS is primarly geared around VoIP - does not really take Video into account.
Personally I always write my own QoS policy using MQC.
HTH>
jjnagel102 Wed, 08/12/2009 - 18:34
Thanks. From what I had read AutoQos seemed more for voice traffic.
visio@charter.net Thu, 08/13/2009 - 08:41
I recently had to design a global QoS solution for VideoConf installation on large dual-MPLS WAN network. Helps with DSCP tag recommendations and queuing.
HTH,
Andy
Here is a really great whitepaper on this exact topic: http://hive2.hive.packetizer.com/users/h323forum/papers/QoSforIPVideoconferencing.pdf
Details:
AF41 is therefore considered the most suitable for video traffic. As there is no advantage in treating voice packets better than the video packets in an IP videoconferencing application, AF41 should be used as
the DSCP value for both voice and video media in a videoconference. The EF marking is not a good choice for use with video conferencing for these reasons:
· Video packets are much larger than voice packets, usually as large as the maximum link
MTU size. If video packets are marked as EF then they will be allowed into the same
priority queue as voice. If a small VOIP packet enters the queue behind a large video packet
(or worse, a whole bunch of such packets), then the delay in the VOIP packet may
increase depending upon the traffic engineering in the network. Such delay will adversely
affect the performance of VOIP applications.
· Given that most EF queues are very small, using them for video traffic may lead to dropped
packets.
· Video coders tend to have much longer coding delays than voice coders, and hence giving
the audio stream(s) of a videoconference absolute priority only causes them to arrive early
and be held in order to achieve lip sync. Therefore, it does not help to put voice packets
associated with a videoconference in a queue with better service than that given to the video
packets.
