Start Before Logon XML Not Taking
Aug 12th, 2009
Following the steps in:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00809f0d75.shtml#svg to configure SBL (ASDM), when I try to assign the XML profile to the group policy (step 11), I hit OK after choosing the XML file and it doesn't take. Just comes back with the "Add SSL VPN Client Profiles" dialog.
I used the XML file provided with the AnyConnect client and just changed the host settings, so the syntax should be right.
Any other suggestions?
benharned Wed, 08/12/2009 - 11:18
Thanks for the link. Ran it, all good.
Well formed: VALID
Schema validation: VALID
Now what? Is there a setting somewhere I missed? I followed the instructions.
Robert Salazar Wed, 08/12/2009 - 11:24
  • Cisco Employee,
what version of ASA and asdm are u using?
what happens if you use cli instead?
benharned Wed, 08/12/2009 - 11:32
ASA 8.2(1)
ASDM 6.2(1)
I'm not the most versed in CLI so I am not totally sure of the right commands. When I followed the examples in the guide, I kept getting an invalid error in step 3 "svc profiles NAME disk0:/..." The indicator was showing under the NAME.
Christopher Ursich Tue, 07/13/2010 - 16:00
+1 here.  I am using ASA code 8.2(2) and ASDM 6.3(1).  When editing the group policy, in the "SSL VPN Client" section, I change the "Client Profile to Download" from "-- None --" to one of my client profiles and click 'OK.'  The 'Apply' button does not become clickable, and when I re-open the group policy for editing, the setting is back to None.
