Not sure if Memory Usage on ASA5520 is acceptable
Aug 12th, 2009
We have a ASA5520 running asa804-28-k8 with 512mb of RAM. It uses about 300mb of memory constantly and I am wondering if thats OK or not.
Also I read in this forum that disabling "Threat-Detection" will win back memory and does nothing to take away form the over all saftey of the FW. This sounds odd, but if I am running high, it would be one service I might consider disabling.
Thanks a million,
Pete
robertson.michael Wed, 08/12/2009 - 07:11
Hi Pete,
Determining an acceptable level of memory utilization is difficult because it depends greatly on your environment (things like code version, enabled features, traffic levels, etc.)
That being said, disabling threat detection is very likely to decrease your memory utilization (especially in some versions of 8.0, which has a few memory leak bugs).
Here is the configuration guide for threat detection so you can decide if you need it or not:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/protect.html#wp1042020
Hope that helps.
-Mike
pener1963 Wed, 08/12/2009 - 07:46
Hi Mike,
Thanks for answering my post. We only use Threat-Detection for logging right now.
I guess we could always buy some more RAM too.
pener1963 Wed, 08/12/2009 - 07:54
Just in case anyone is interested. Disabling Threat-Detection gave me 50mb back.
