Zach Seils Wed, 08/12/2009 - 07:57
  • Cisco Employee,
Hi Ryan,
I have a couple of questions:
1. What version of WAAS are you running?
2. Have you recently changed the amount of the memory in the WAE?
Zach
ryan.hoenle Wed, 08/12/2009 - 08:00
Thank you Zach!
It is running 4.1.3b and no, I have not recently upgraded the memory, but when I did, I cleared the DRE cache.
Should I do this again after the 4.1.3b upgrade?
-Ryan
Zach Seils Wed, 08/12/2009 - 08:02
  • Cisco Employee,
Thanks for the reply.
Can you check syslog.txt for any "%WAAS-RE" messages?
If there was a change in the WAE memory configuration, I suspect you may be running into CSCsy47235.
Zach
ryan.hoenle Wed, 08/12/2009 - 09:54
Zach,
That was exactly it. Resolved. Thank you again!
-Ryan
