VPN Client authentication question
Answered Question
Aug 12th, 2009
Hi friends,
I recently started at a new company, where the Cisco VPN Client is used by all remote Windows users. I am not familiar with the client. I see by our Remote Access Policy that the clients authenticate using PAP. This immediately drew my concern.
My question is does this present a security threat? Even though the auth is unencrypted, it is still happening within a 3DES IPSec tunnel, right? What is the best practice with regards to using the VPN client and authentication?
Thanks in advance!
Equipment:
Cisco VPN Client v5 (latest build) on Windows XP SP3
Microsoft IAS (RADIUS) on W2K3 Server R2 x64
Cisco 3825 Router
IOS 12.4.24T Adv IP Services
Correct Answer by sziaulla about 7 years 6 months ago
if my understanding is correct your VPN client is terminating on 3825 router. the client gets the username/password prompt after getting phase1 up therefore it cannot be clear text.
i hope this helps
regards
-Syed
Overall Rating: 4 (1 ratings)
Correct Answer
sziaulla Wed, 08/12/2009 - 11:35
i hope this helps
regards
-Syed
cooperben Wed, 08/12/2009 - 12:45
Yes correct, all clients terminate on the outside interface of our 3825 router. We use group authentication w/ pre-shared key.
From what you are saying, I understand that Phase1 negotiation comes up first, thus wrapping all further communications in 3DES IPSec encryption. This then includes the user/pass transmission.
So therefore, using PAP is no big deal in this configuration? (I am assuming not, otherwise it would not be designed to work this way.) But I just want to be sure.
Thanks in advance for all input.
