NAC -CCA Agent Auto URL
Aug 12th, 2009
I have CAS with Agent 4.5.1 , when users try to get authenticated he needs CCA Agent to be downloaded and installed on client PC , its not happening automatically ..users opens a browser type the link ..first time should be redirected to CAS for CCA agent download page , but its not happening ..but when they type the IP address of CAS eg: https://cas-ip , then it asks to download the CCA Agent , i have complete DNS setup both reverse lookup / forward lookup working also proxy configured still it does n't goes out there..... where with ip address everything works fine ..does any have idea how to move forward
mdazhar Thu, 08/13/2009 - 00:45
when typing IP will do the job , have no idea if still could be routing issues L3 , also do i need any route on Proxy server to reach CAS or on DNS server something like this ...have some tested this setup then pl
Yudong Wu Thu, 08/13/2009 - 06:58
Which ip will do the job? CAS' IP? If yes, I believe that Agent download can be triggered when the packet to will go through the CAS.
If you have service contract with Cisco, I suggest you to open a TAC case.
mdazhar Thu, 08/13/2009 - 07:26
I already opened TAC # 5 engg changed no solutions , cisco TAC team is completely unaware about their products itself or they not upto the mark for the solution at one time i thought to switch with Juniper
since this solutions already sold , i hope to have valid solutions let s re assess to find the solution
1. when type the IP of CAS agent gets downloaded
2. when type of doens 't go
3. DNS both forward & reverse lookup working fine
4. Proxy has been configured in CAM
does any issue needs here missing to fill the GAP.
Yudong Wu Thu, 08/13/2009 - 09:46
troubleshooting this will depend on how it was implemented in your network. Such as in-band or out-of-band, layer 2 or 3 mode, and CAS is virtual Gateway or real Gateway.
The general mistakens could be:
1. SVI interface for auth vlan --> auth vlan must be pure layer 2. In a word, you need make sure the packet from client should go to CAS when they try to browser
2. if it is layer 2 mode, management subnet must use IP from trusted subnet but vlan ID from auth vlan
3. if it is layer 3 mode, make sure you have static route configured for user's IP address.
mdazhar Thu, 08/13/2009 - 10:43
its been implemented as L2-OOB-VGW (CAS)
and setup is working fine , when agent manually installed , authentication process takes places successfull and valid policy and posture assements
when i said everything working means it dam working for around 100 PC's
only i need to redirect when they open the (first time , where no CCA agent installed ) then it should get the download from CAS , as i said earlier using IP address cas will ask users to download the KIT...
i really appreciate your effort to response let s hope with more tips we can resolve the problem
