2811 - dual GK and GW role
Aug 12th, 2009
Customer requires resilent gatekeeper solution between two CM clusters.
Customer currently has Cisco 2811 providing PSTN breakout.
Will the integrated voice/video GK, IPIP GW, TDM IP software feature enable the 2811 to provide BOTH gatekeeper and VoIP gateway funtionality?
Assuming the answer is yes, are there any limitations with implementing this dual role on a single platform?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 08/12/2009 - 10:54
  • Hall of Fame,
    Founding Member
Yes.
The only limitation is the amount of overall traffic, keep it within reasonable limits.
