Can not access ASAs inside interface via VPN tunnels
Aug 12th, 2009
Hi there,
I have a funny problem.
I build up a hub and spoke VPN, with RAS Client VPN access for the central location.
All tunnels and the RAS VPN access are working fine.
I use the tunnels for Voip, terminal server access and a few other services.
The only problem I have is, that I could not access the inside IP address of any of my ASAs, neither via tunnels nor via RAS VPN access. No telnet access and no ping reach the inside interfaces.
No problem when I connect to the interface via a host inside the network.
All telnet statments in the config are ending with the INSIDE command.
On most of the ASAs the 8.2 IOS is running on one or two ASAs the 8.0(4).
For the RAS client access I use the Cisco 5.1 VPN client.
Did anybody have any suggestions?
Marcel
JORGE RODRIGUEZ Thu, 08/13/2009 - 05:28
  • Green, 3000 points or more
Marcel,
Simply add on the asas you want to administer through the tunnels
management-access
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/m.html#wp2027985
for asa5505
management-access inside
for all others if you have management interface management0/0 defined then:
management-access management
then you may need to allow the source , for example if RA VPN pool network is 10.20.20.0/24 then you tell asa that network cann administer asa and point access to inside, but sounds you have this part already.
telnet 10.20.20.0 255.255.255.0 inside
http 10.20.20.0 255.255.255.0 inside
same principle for l2l vpns
JORGE RODRIGUEZ Fri, 08/14/2009 - 09:50
Marcel, are you all set or still have issues managing asa through ipsec?
puseth Tue, 08/18/2009 - 11:07
can you add this command in your Asa and test it out...
