08-12-2009 11:07 AM - edited 03-06-2019 07:13 AM
The server 10.6.22.10 I'm pinging resides on FastEthernet0/0is 10.6.1.1/16. If I send the ping from f0/0 I get reply -below is the output:
Packet sent with a source address of 10.6.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
rtr-dallasdc#
Aug 12 16:59:48.784: IP: tableid=0, s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:48.784: IP: s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:48.784: ICMP type=8, code=0
Aug 12 16:59:48.788: IP: tableid=0, s=10.6.22.110 (FastEthernet0/0), d=10.6.1.1 (FastEthernet0/0), routed via RIB
Aug 12 16:59:48.788: IP: s=10.6.22.110 (FastEthernet0/0), d=10.6.1.1 (FastEthernet0/0), len 100, rcvd 3
Aug 12 16:59:48.788: ICMP type=0, code=0
Aug 12 16:59:48.788: IP: tableid=0, s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:48.788: IP: s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:48.788: ICMP type=8, code=0
Aug 12 16:59:48.792: IP: tableid=0, s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:48.792: IP: s=10.6.1.1 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
If I send the pings from 10.200.16.22 F2/1 they time out.- below is that output but notice FIB.
Aug 12 16:59:33.836: IP: tableid=0, s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:33.836: IP: s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:33.836: ICMP type=8, code=0.
Aug 12 16:59:35.836: IP: tableid=0, s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:35.836: IP: s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:35.836: ICMP type=8, code=0.
Aug 12 16:59:37.836: IP: tableid=0, s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:37.836: IP: s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:37.836: ICMP type=8, code=0.
Aug 12 16:59:39.836: IP: tableid=0, s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), routed via FIB
Aug 12 16:59:39.836: IP: s=10.200.16.22 (local), d=10.6.22.110 (FastEthernet0/0), len 100, sending
Aug 12 16:59:39.836: ICMP type=8, code=0.
There is a static arp entry for the 10.6.22.10 device also. Microsoft Net Load Balancing.
If I do a show ip cef I don't see 10.6.22.1 in the table but it's in the routing table.
Thanks guys..
08-13-2009 05:07 AM
The second output shows that packets are indeed being sent, now just check if 10.6.22.10 has a proper default gateway configured. If possible install wireshark on this system and observe the packet flow, it will give a more clear view as what is happening when you are sending ping from 10.6.22.10 to any ip beyond its gateway.
