PIX/ASA 7.2-8.0 Master Command Reference vs. Command Lookup Tool disparity
Aug 12th, 2009
CLT
inspect esmtp - default = enabled for 7.2 and 8.0
Master Command Reference Document = disabled for 7.2 and 8.0
Anyone in production that can verify which one is indeed correct.
Jim Abercromby
CCNP
jabercromby Wed, 08/12/2009 - 18:59
Sushi,
Cisco Security Appliance Command Reference
For the Cisco ASA 5500 Series and Cisco PIX 500 series.
Software version 8.0(4) - revision number different
Just looked at it again disabled by default.
Software version 7.2(2)
I got these logged in via cco account.
PDF books.
Would you like me to email them to you.
For hands on verification.
jabercromby Wed, 08/12/2009 - 19:08
Sushi,
If you look at the html content i.e. Command Refs for
these yes it shows inspect esmtp as being enabled by default
and the Command Lookup Tool states as such.
If you actually download the .pdf command reference books
for 8.0, 8.0(4) and 7.2(2) you will see that these indeed show
inspect esmtp as being disabled by default.
I can test this via PEMU (emulation) at best.
But it would be nice if someone in production can vouch
one way or another as to what is truly correct.
If not I will escalate the matter through formal Cisco
channels to have the documentation and support content
changed.
Regards.
Jim Abercromby
