08-12-2009 11:49 AM - edited 02-21-2020 03:37 AM
We have a ASA 5520 running version 8.x that currently has 512MB of DRAM.
I would like to upgrade the DRAM to 1GB
Questions:
1. How many slots DRAM slots does the 5520 have?
2. I found this part:
http://www.memoryx.net/asa5520mem1gb.html
Which looks to be the right one. Is there any where I can llo to be sure? I have been been looking and looking but I cant find any hard documentation about the DRAM modules I can use for my 5520.
Thanks a million,
Pedro
Solved! Go to Solution.
08-12-2009 01:25 PM
It should have four.
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/guide/procs.html#wp1076043
The only supported memory upgrade must come from Cisco, part# ASA5510-MEM-512=
The 'Cisco' part number at memoryx does not exist in Cisco's price list. Also I believe that is for the AIP module, not the chassis. I believe the chassis only supports 512MB chips. The link below is the one you want.
http://www.memoryx.net/asa5520.html
It only shows it having a single bank though. I don't have a 5520 in the lab to take a look, but the documentation should be accurate.
08-12-2009 01:25 PM
08-24-2009 03:34 AM
Was it ever confirmed if a memory upgrade is supported on the 5520?
08-28-2009 09:17 AM
I found out that the Max that the ASA5520 will take is 512mb, so if you have less than 512 you can upgrade. And there is only one slot.
08-28-2009 09:33 AM
That actually isn't true...I have someone who took one 512 chip from a 5520 and put it into another 5520 and it works fine. But is it supported by TAC. I'm told there a 4 memory banks in the 5520.
