CSA 6.0 Problem with \??\ preceding a file.
Aug 12th, 2009
We have a message in the Event Log about a Kernel functionality being modified by the module:
\\??\Windows\system32\drivers\mkbd.sys
\\??\Windows\system32\drivers\mkbd.sys is monitoring the keyboard.
Any idea what the "??" mean? We can't use the wizard to tune it.
Thanks in advance.
jan.nielsen Fri, 08/14/2009 - 14:36
Could be vmware workstation virtual keyboard driver. You should be able to whitelist as an option in the wizard.
pmccubbin Sun, 08/16/2009 - 08:52
Hi Jan,
Thanks for the reply.
When we try to whitelist via the Wizard the CSAMC throws an error and doesn't allow this operation to procede.
I am opening a TAC case and will post results.
pmccubbin Wed, 08/26/2009 - 09:26
Just wanted to offer an update. We have a TAC case open and the Business Unit is looking into the case.
Attached is the error message.
As a bit of background we are running the CSAMC on a VMWare machine.
When I hear more I will post it. Thanks.
deshaw Fri, 08/28/2009 - 01:34
We have also faced similar issues with CSA 6.0 and this known issue is fixed in 6.0.0.220 and later versions.
daneilhudson Fri, 09/11/2009 - 04:13
You could manually write a rule using **\Windows\system32\drivers\mkbd.sys as a definition for the application. I suspect that @system would work as well. Just create an application class and add that as an exception to the triggering rule.
