08-12-2009 01:33 PM - edited 03-13-2019 06:34 PM
Can the same auto qos voip be set on an ASA 5505? I can do this on basic routers all day long.
Solved! Go to Solution.
08-12-2009 07:15 PM
AutoQoS is supported only in routers and switches.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
08-12-2009 07:15 PM
Best regards,
- Adrián.
08-13-2009 11:54 AM
IT Figures - Routers are EXTREMELY superior to ASA's - ASA's SUCK and have WAY too many limitations - the Entire IT world has been scammed!
10-29-2010 07:00 AM
Check this out, it is only a few commands.
http://brian-kayser.blogspot.com/2010/10/doing-asa-quality-of-service-qos.html
