VPN-Specific Logging on PIX?
Aug 12th, 2009
Is there a way to send VPN-specific syslog messages to a logging server on a PIX running 6.3 code?
I'm able to do this in 7.X code but I can't find a way to send any type of VPN syslog messages to a syslog server.
Yudong Wu Thu, 08/13/2009 - 12:22
Not sure if you can do this way...
It's not convenience and just a workaround...plus you will get other level 1 syslog message.
1. In syslog message document, find all vpn related message #.
2. change their level to 1
logging message [syslog_id] level 1
3. then only send that level message to logging server by "logging trap [level]" command. Yes, you will get some level 1 syslog messages.
