Read Text and Create Generated Prompt
Aug 12th, 2009
I will like to have a script thats read from a text file on the CCX Windows folder and generated the prompt via Nuance TTS.
Is there a way to read the text values on the Text file? Help is very appreciated.
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Thu, 08/13/2009 - 05:48
  • Cisco Designated VIP,
    2017 IP Telephony
Also you should not be reading from the file system directly. This is not supported and will break when you upgrade to 8.0 (Linux appliance). You should be reading from the Document Repository or performing an HTTP GET.
