Max VLANs on ISL??
situwayne
802.1Q frame has a 12 Bits VLAN ID which translate to maximum possible 4096 vlans on a trunk.
ISL frame has a 15 Bits VLAN ID. based on this I would assumed ISL can support more than 4096 vlans. however, I'm being told only up to 1024 vlans are supported on a ISL trunk. is this true? if so, is there something in the ISL frame I can use to calculate the max vlan?
Giuseppe Larosa
Hello Wayne,
original ISL specification supported only 1024 vlans but later a revision of the protocol allows for support of 4096 vlans like it happens for 802.1Q.
see
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml#pre4
the vlan-id field has been 15 bits wide since first version of ISL.
You need also to take in account that ISL has more overhead and that 802.1Q is standard based.
Your lab results look like correct.
to be noted that VTP is still limited to vlans 1-1024 in version 2 and vtp mode transparent is needed to use the extended range
Hope to help
Giuseppe
5 Replies 5
iyde
Level 4
Level 4
I believe that ISL has been designed to use only VLAN 1-1005. So it is not a matter of how many bits are available for VLAN id but more of a design decision.
That's what all the documents said. I've configured ISL on these Cat3560 switches. I don't have 1000+ vlans created, but the trunk is clearly allowing more than 1005.
SW1#sh run int gi0/1
Building configuration...
Current configuration : 145 bytes
interface GigabitEthernet0/1
switchport trunk encapsulation isl
switchport trunk allowed vlan 1-2048
switchport mode dynamic desirable
end
SW1#sh run int gi0/2
Current configuration : 107 bytes
interface GigabitEthernet0/2
end
SW1#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 desirable isl trunking 1
Gi0/2 desirable isl trunking 1
Port Vlans allowed on trunk
Gi0/1 1-2048
Gi0/2 1-4094
Port Vlans allowed and active in management domain
Gi0/1 1,5-6
Gi0/2 1,5-6,4000
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1,5-6
Gi0/2 1,5-6,4000
SW1#
SW1#sh int gi0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: trunk
Administrative Trunking Encapsulation: isl
Operational Trunking Encapsulation: isl
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 1-2048
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
I read that both ISL and 802.1Q support 4094 vlans. What you see as allowed VLAN is configured with a command: "switchport trunk allowed vlan [add|all|except|remove] vlan-list" ..... So one thing is the number of VLANs it supports and a different thing is the number of VLANs allowed in a trunk. Hope this helps.
Giuseppe Larosa
Hello Wayne,
see
Hope to help
Giuseppe
very good info. thank you so much.
