FAX sending Problem
Aug 13th, 2009
I have CME 7.1.
I connected one fax to ATA SCCP ( I think the version for ATA is 3.1)
the problem when we need to send fax the other faxes ringing but we were not able to send the fax
CME uses FXO port to send faxes. I did the following configuration:
voice-port 1/2/3
connection plar opx 1500
dial-peer cor custom
name fax
dial-peer cor list Call-FAX
member fax
dial-peer voice 116 pots
corlist outgoing Call-FAX
description FAX calls
destination-pattern .T
fax rate disable
port 1/2/3
forward-digits all
ephone-dn 50
number 1500
corlist incoming Call-FAX
ephone 50
mac-address 00XX.XXXX.XXXX
max-calls-per-button 2
type ata
button 1:50
Overall Rating: 4 (1 ratings)
paolo bevilacqua Thu, 08/13/2009 - 02:39
  • Hall of Fame,
    Founding Member
Recommend you use an FXS port for fax.
ATA is source of trouble for faxes.
JustForVoice_2 Thu, 08/13/2009 - 03:21
I know that but unfortuntly I do not have any FXS in this project.
shall I use h323 ATA frameware rather than SCCP.
paolo bevilacqua Thu, 08/13/2009 - 03:32
  • Hall of Fame,
    Founding Member
You can try, then follow the guide "troubleshooting ata for fax" from the search box.
ivarnhagen Thu, 08/13/2009 - 07:07
I have also found that the following settings on the Fax helped if connected to an ATA:
send/recieve rate 9600baud
ECM off
