Java exception loading CRS script
Aug 13th, 2009
I have CRS 4.0(4) and most of the scripts I can open without any problem. But when I'm trying to open script with some java objects (regarding classes for date, month, year)I get this exception:
"Failed to load script file; com.cisco.io.IOException: unread block data; nested excpeption is: java.lang.IllegalStateException: unread block data"
I suspect it's the compatibility issue and that probably I would need a newer version of CRS, or maybe is something else? Cause, on version 5.0(2.045) I can open it without any problem.
Do you have any idea what could be the problem?
Thx!
Jelena
